Searching_Ut's avatar
Searching_Ut
Andersen Ultimate with Lippert 1621 HD Pin Box
Folks, I'd ask in this post that everyone please stick to factual, technical information type responses if any, and avoid emotional responses, or the personal attacks which often seem to become the case in discussions about the Andersen Ultimate hitch.
As I posted earlier, in a post the moderator had to rightfully lock, the Pin box base plate on my 2016 Bighorn fifth wheel was bent by the set screws on the Kingpin adapter for my Andersen Ultimate hitch. I posted photos in that post. I had addressed the issue with my dealer, and they said "that happens with that hitch", and said it wasn't an issue they would address claiming Andersen said it was not a problem. I had difficulty accepting this second hand information and went to Andersen for their response, evidently initially having e-mail issues in getting their response, which follows:
"Here's the response I sent previously. Also I spoke to my technical support again today and they are going to go ahead and send that spacer out so, you should see that within a couple days. Just be careful not to put it over any of the set screws. I apologize for the inconvenience.
Lippert used a thinner material to make the pin box is made out of on this particular model, and that has allowed this type of bending. You can put a spacer in and tighten it up. If you'd like we can send you a spacer. This will increase surface area around the pinbox to prevent that from happening any more.
As far as the intentations in the truck bed, can you please send some pictures of both the bed & base? If you're using the older style Ultimate, we can swap it out for newer base as we did have a few problems with that.
Thanks for your help. Have a great afternoon"
The pin box in question is a Lippert, model LIPP1621 HD, GVRW 18,000 lbs. and it is installed on a fifth wheel with a dry weight of 12,084lbs, dry pin weight approximately 2500lbs, GVWR of 15,500 My understaning is that this is one of the most common pin boxes currently being put on Lippert frames, so if you're using an Andersen Ultimate on a newer fifth wheel trailer with a Lippert 1621 pin box you might want to keep an eye on it and contact Andersen for spacers if you start having problems.
Again, I'd like to request this posting stay informational, factual, or at least keep opinions on the design of a technical nature, avoiding personal attacks, or emotional responses. For once I'd like to see an Andersen Hitch posting not become a burden on the moderators.
