up2nogood wrote:
Me Again wrote:
Michelle.S wrote:
So then Andersen is saying that their hitch will absorb up and down shock like an Air King Pin and fore and aft shock like the Mor/ryde.
So my question is, with all the movement there must be in that hitch to do all that, how long before it fails, since it appears to be mounted pretty ridged.
No it the pickup bed floor that does it! Chris
Yes, the same as the B&W, dented beds . Which most do not mention or the cure. Shims in low points of the bed. Which cures both hitches of a problem.
I have told of my dented bed and bent base on my 18K Companion. When I talked to B&W about it they sent me a new base with the filler strips that cured the problem. Since they have changed the base and upped the companion to 20K.
