- wpsharpshooterExplorerIts not slammed.. But the angle does look pretty severe. Tons of good ideas posted.. Just need to narrow them down and see whats gonna work for me.
- tinner12002ExplorerYour bike must really be on the ground...I have a second bike, lowered 02 Heritage and I was surprised it didn't rub at the break over but it cleared in my 30' Adrenaline and I even have hauler raised at the axles with 16" wheels and a 2" lift blocks.
- atwowheelguyExplorerDoes your toy hauler have one of "beaver tail" sloped sections at the rear of the cargo area? Some have them to help with the transition.
There's a cautionary tale for others here. It might be a good idea to take the bike to the camper before purchase if it's a low ground clearance cruiser.
OP might find a solution at www.hdforums.com.
- Tzman4ExplorerDitto BigDogF250 . Raising the front end will help a lot. Have had to do that before.
- asullivan920Explorercheck these out. Little expensive but maybe you can use the idea and make it of wood. trailer ramp extension
azdryheat wrote:
My FLHTK goes in just fine. What trailer do you have?
Probably a good tid bit of info to know,Sorry... I have a 2016 hyperlite XLR 24HFS - DirtclodsExplorer IIIf you have a curb available that well work as well.
- fj12ryderExplorer IIIBe careful using the clutch to slow/stop the bike when backing out. Some bikes could be damaged by the engine spinning backward. I use both front and rear brakes when I back mine out.
- Carlos___RanaeExplorerMy Midnight Silverado bottom out at the bottom of the ramp and at the top. A piece of 2 X 4 at the bottom and at top of ramp solved the issue.
- azdryheatExplorerMy FLHTK goes in just fine. What trailer do you have?
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
