fj12ryder
Apr 18, 2016Explorer III
If I had that problem, I would add a hinged plate that would support the weight of the bikes as they roll over it, and could be swung out to make the door longer. Then put supports under the door's upper edge to raise it enough so you can transition into the toyhauler. It would take a little longer to set up, but not that bad.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
