Braveheart
Apr 18, 2016Explorer
What about building a ramp that lays on top of the toy hauler ramp that reduces the angle? It would only need to be as wide as you need to drive up. You could also lift the ramp by placing a few 4x4 under it to reduce the angle and then build a ramp that overlays the THers ramp.
Another option.... Lift the ramp 10-12" (what ever height needed) support the underneath side with blocks or jacks, metal feet, etc. then make a ramp extension from and attach it with heavy duty piano hinge.
I would assume someone has a better solution, but this is one.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
