Me Again wrote:
familyof3 wrote:
I got the marathons too last year. Already blew one Thursday. I thought they would hold up but I guess I was wrong I will be checking on my rims and see if the will hold up the 110 psi but I doubt that they will knowing my luck. If not I'm going to get the 17.5 tires and rims It's all about the cost Either you upgrade to good tires or pay to keep fixing your skirting and fenders. Lol. But mine is a triple axle so that could be a lot of my problems. Maybe the LT tires will double the life of a ST tire and come out in the long run.
6 LT235/85R16E or LT245/75R16E tires are good for 18252 pounds on the axles, do you have more than that? If not, they why don't you just install Michelin XPS RIBs or Bridgestone Duravis R250s? You stay with 80 inflation tires and current rims. Next tire change would be in 6 to 8 years! Chris
Thanks Chris
I'll check into Michelin XPS RIBs or Bridgestone Duravis R250s tires. I don't believe it's the weight. It's gotta be the three axle and heat. Guess I'll call around and see where I can find me a set of tires. Thanks again Chris
