MFL
May 20, 2018Nomad II
AFAIK, all Jacks are similar. You did not say if the red light, on the bottom side of the antenna is on. Do you know where to look for it? It can be hard to see in bright daylight, but easily seen in the dark. If not, there is no power to it. It could be a bad/loose coax connection also. In any case, the King Jack works well, if properly installed.
Jerry
Jerry
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
