Dukecity426
May 21, 2018Explorer
Well Folks I FIXED IT! Here is what happened.I got up at 5:00 AM (when it was still dark) and went outside to see if the red light was on at the bottom of the King Jack antenna, and it was. Then I went inside removed the directional handle and the surround. I used a bore camera and looked at the bottom side of the antenna and saw that the coaxial cable was hooked up. Then I used a 19 inch Vizio TV as a test TV. Went into the bedroom and scanned for antenna channels there. To my surprise I received 68 channels. So my problem was between the signal booster and the living room TV. Removed the radio and again used the bore camera and found a splitter. Pulled the splitter and found that all the cables were in the out position and no input. So I looked inside the cabinet and used a coat hanger and pulled a coaxial cable that was not hooked up. Took that cable and installed it to the input and now we have TV everywhere.A long process but I couldn't have done it without the suggestion from ya'll. So Thanks again. Bruce
About Fifth Wheel Group
19,040 PostsLatest Activity: May 24, 2026
