rhagfo
Oct 01, 2015Explorer III
WE-C-USA wrote:
Back to the OP, John's ??. Does it make a difference, I don't know.
But on my Reese 16K hitch, it has a warning sticker.
Quote--'Install 4 pull pins & spring clips as shown(clips on outside of base rails)' end quote. There's also a drawing on the sticker showing exactly that.
The only reason I can think for the warning is, you'll be able to see, clearly, that the spring clips are installed correctly.
I've always installed mine that way.
Interesting, I install mine with the clips under the legs, out of sight out of mind for some joker! I can easily still see, I also install the clips from the center making it very hard to reach when the trailer is attached.
About Fifth Wheel Group
