Njmurvin
Jun 19, 2017Explorer II
Newman, I thought of that (too many watts). But, the inverter has error codes and alarms for that. Besides, the vacuum is only rated 1000 watts and the inverter is rated at 2000 watts (1800 sustained). Everything else in the trailer is off (except parasitic loads). I have another vacuum (small shop vac) that works fine. So far, it's only this Shark vac that seems to be a problem.
Rjxj, I assume you mean the DC cables powering the inverter. They are huge (4/0) and maybe 3 or 4 feet max.
I am still thinking it may be a grounding issue but am curious why this vacuum is the only device (so far) that behaves like this.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
