time2roll
Jun 19, 2017Nomad
Assuming the vacuum has a ground plug... can you use a two prong extension to unground the vacuum?
I am thinking the motor induces a ground current in the RV when operating.
Then try plugging the RV into the inverter with a two prong plug.
Have you tried another vacuum?
2000w inverter should power anything that plugs into a regular outlet.
Do you have the fridge and water heat set to propane only?
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
