Ed9824v
Jun 19, 2017Explorer
time2roll wrote:
Assuming the vacuum has a ground plug... can you use a two prong extension to unground the vacuum?
I am thinking the motor induces a ground current in the RV when operating.
Then try plugging the RV into the inverter with a two prong plug.
Have you tried another vacuum?
2000w inverter should power anything that plugs into a regular outlet.
Do you have the fridge and water heat set to propane only?
good question on the water heater on electric, that thing can be 1000 to 15oo watts alone. I has issues at one campsite tripping there breaker and turns out the electric water heat was just too much for this maybe weak breaker
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
