DogTrainer
Jun 29, 2017Explorer
Make is easier and then pick it apart.
GFI only trip when two much current is being pulled out of plug as in current which equates to watts P=ei or power is equal to voltage times current OR
your device has a ground issue directly to the plug. plugged into an inverter can bypass or isolate the ground issue as the inverter will mask it.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
