Njmurvin
Jun 30, 2017Explorer II
DogTrainer wrote:
Make is easier and then pick it apart.
GFI only trip when two much current is being pulled out of plug as in current which equates to watts P=ei or power is equal to voltage times current OR
your device has a ground issue directly to the plug. plugged into an inverter can bypass or isolate the ground issue as the inverter will mask it.
I think there's some strange grounding issue. There's no way the vacuum + parasitic draws are exceeding the inverter's capacity (2000 watts peak and 1800 continuous). Besides, such an overload would exhibit different behavior with error codes on the display and an alarm.
It's most likely something in the grounding BETWEEN the trailer and the vacuum because the vacuum works fine from the inverter as long as the trailer is not also plugged into the inverter.
About Fifth Wheel Group
19,042 PostsLatest Activity: Apr 15, 2026
