Njmurvin's avatar
Njmurvin
Explorer II
Jun 19, 2017
Any electrical experts out there?
I have strange one. I have installed a Xantrex ProWatt 2000 pure sine wave inverter. I plug my shore cord into the inverter and turn off my trailer's converter/charger. All outlets and 110V devices work great running off the inverter. I have tested the microwave, ceiling fan and several plug in appliances (e.g. Bose charger, small hair drier, etc.) and all of those work perfectly.
Here's where things get interesting. I have a small Shark vacuum cleaner that's rated at 1000 watts. If I plug into any outlet in the trailer, the GFI on the inverter trips. If I plug it directly into the inverter WHILE THE TRAILER IS ALSO STILL PLUGGED INTO THE INVERTER, the GFI on the inverter trips. However, if I unplug the trailer from the inverter and then plug the Shark into the inverter by itself, it works fine. There are no other active loads on in the trailer during this test and there is no error displayed on the Xantrex inverter LED display. It also works fine if the trailer is plugged into real shore power.
I suspect this points to some sort of grounding issue. The inverter's negative side goes to a shunt where all the negative loads in the trailer go (essentially to the negative side of the battery bank). The inverter's chassis ground lug goes to the trailer frame (per installation instructions).
So far, this is the only electrical device that does this. Any ideas why this is happening?
