FishOnOne
Dec 01, 2015Nomad
Me Again wrote:alexleblanc wrote:
the 6.7 has proven to be extremely reliable up to date, problem is people post about issues, not great reliability. The 1% having troubles can be very vocal. Mines got 70k km's and has been trouble free to date.
Very true, and when the cost is 10,500-12,000 to fix a failed CP4.2 injection pump and the manufacturer refusing to cover it under your warranty, it tends to make the head lines.
As stated earlier both GM and VW fix these pump issues without blaming the consumer. Ford highly deserved black eye is for not standing behind there product. We just purchased a new truck with a CP3 injection pump, if we had purchased a truck with a CP4.2 pump it would have been a GM based on these warranty coverage issues.
I would bet that most people that have had a GM CP4.2 pump failure and not even aware that that was the issue. As GM just fixes it and gives in back to the owner "all fixed and ready to go" enjoy!
Given the 6.0 and 6.4 track record, this has not been very smart on Ford's part. Or the failure numbers are higher than we know and it would effect their bottom line more by masking over the problem than p!$$!ng off a small group of customers. Chris
I diesel tech recently reported at FTE that all but 1 HPFP that he replaced had either gas or DEF fluid in the tank and some people expect this should be covered under warranty? Also he stated he replaced one HPFP with no signs of rust on the HPFP or DEF crystals and it was covered under warranty.
GM will now look for any signs of fuel contamination and no they will not just blindly replace a HPFP without inspecting and getting approval from GM warranty.
My cousin has replaced several Ram/cummins CP3 fuel pumps last year due to gas contamination and one that had galvanized steel flakes in the filter in which Chrysler voided the warranty on both accounts. As a matter of fact he doesn't even want to be around the customer when they are notified of the warranty denial and they want to see why it failed.
About Fifth Wheel Group
