sdetweil
Aug 30, 2014Explorer
any test before connecting trailer to generator (50amp)
I found an Onan 7kw generator last fall, fixed the bad drive pulley coupler and replaced the belt.. tuned it, new plugs...
will convert to tri-fuel.
got it all wired up to a 50amp outlet today, started it up and used my PI circuit tester, and it says all is good.
is there anything else I should test before hooking the trailer up
and turning on the A/C? I can and will power up smaller things first.
tvs, microwave..
do I need to flip the 120v breakers off, and enable 1 at a time?
the generator is full throttle all the time. pretty quiet all in all.
have the metal box built, just have to cut the floor in the front compartment.
tvs, microwave..
