ChadHubbard wrote:
Hi
We have a 32foot 2003 Fleetwood Pride. Someone mentioned they were manufactured in Texas, I think/thought they were manufactured by Pride Manufacturing in Louisianna. Maybe I am wrong. Ours set for quite some time indoors. Had a slide motor stuck and I had to remove it and 'unstick' it I have a post somewhere on that, might be helpful to you. Cooling unit went out of the refrigerator, but that seems to be common. Bought an Amish (I think) replacement and did the work ourselves. Works fine now.
We have a 2015 Ram 3500 srw pickup. The bed rails were too high for the camper to set level. Seems common for new 4x4 trucks with older 5th wheel campers. Our solution was a flat bed, goose neck hitch, and welding 5" goose neck onto the 5th wheel hitch plate. Some say that is ok, some say that is destined to fail. So far, so good for us. I have a post on that with some pics.
It has been good to us, but esay usage and don't pull it long distances.
If you have any specific questions I would be happy to try to answer them.
Thank you so much. We did purchase the camper. It does seem to have a few issues now that we are digging deeper into it, maybe you can help?
1. It is leaking around the skylights. I think we should just recoat the whole roof, it looks rough. Do you have recommendations?
2. The slide the bed sits on, might move a couple of inches then stall. The switches don't work for the two bedroom slides. They work if you put jumper cables on the wires it will work. Any ideas/recs?
Thank you!
