thomas201's avatar
thomas201
Anybody maxing out an F150, by J2807?
I am looking to trade out of my current F250, 6.7 diesel in 2020. My 5er is about 1240# on the pin and 9300# loaded for a long trip. I know it is light on the pin, but with two extra spare tires in the basement plus carrying everything in front, this is as heavy as I can get the pin. It is 2011 and we are keeping it, it does tow nice.
So who is towing a 10K 5er, with the new F150 and 3.5 ecoboost? With 2 people, the dog and our usual cabin junk, we got about 900# in the cab. Using the Ford specs, 17" wheels, crew cab, rails and fifth wheel; I should still have well over 2000# of payload, so with the 1240 pin, I am good. The camper is well under the max. So the question again, I want the opinions of those actually towing about 10K, how do you like it?
Please no "you got to have a 1 ton, and you need a dually responses."
  • You can do It but the issue with the Heavy Duty F150 is that it runs out of rear axle capacity before it runs out of payload.
    I’d spring for a 3/4 ton gasser.
    Now a HD F150 and a TT..great Combo!
    Thanks and JMHO.
    Jeremiah
  • As a loyal Ford person for the past 20 years they are my go to truck. I still drive my 2000 f150 5.4 gasser daily. Last October I bought a 2017 f250 6.2 gasser. It is a beast towing our 7500 lb TT as if it was a utility trailer. I found a nicely equipped f250 gasser was more economical to buy than a f150. The big difference is suspension, rear end, transmission , horsepower and payload capacity.
  • There are SEVERAL different towing/payload packages available for the F150. DO NOT TRUST THAT YOUR SALESPERSON KNOWS THE BEST COMBINATION!!
  • I think you will hate yourself in the morning!
    Seriously, maxing out a vehicle is a mistake we only make once.
  • I can't directly answer about towing a 5th wheel of that weight with a 150, but I may have some data that might help.
    First to the payload. To get max payload in a 150, I believe you have to go to the 18" wheels. With 17" wheels you lose 200-400lbs off the max depending on whether you are 2 or 4 wheel drive. You lose more with 4 wheel drive. That's a whole can of worms that you have to decide. I have an opinion and so does everybody else. We can cut to the chase and avoid the typical discussion and I'll just call you crazy whichever way you decide and we'll be done!
    I tow a lot of trailers a lot of miles. Car hauler, boat, dump, cattle and RV. Everything but the RV I've towed with both a 150 max tow 4X4 SB and a 250 4X4 SB. With the boat and other bumper hitch trailers I didn't see a huge difference if any.
    I do see a big difference in my gooseneck cattle trailer. I typically haul it at 7,000 to 11,000 pounds. Being a live load, there is some motion there even on a flat straight road. Pulling it with the 150, there's always a little steering involved correcting for the movement of the cattle and reaction to bumps. The cattle moving can change side to side loading and pin weight as you go. With the 250, you are barely aware there is any movement at all the stability on the road is much better. I would probably attribute it to both a stiffer rear suspension on the 250 and stiffer tires.
    Whether that transfers to pulling a 5th wheel or not, I can't tell you. If I were pulling a 5th wheel of the weight you have, I'd go with a 250. My opinion is that it will give you an easier drive. YMMV
