Ram_and_5ver
Dec 30, 2017Explorer
slapshot12 wrote:
I tow my Momentum which is 102" wide with a '17 F-350 saw crew cab short bed and it tows just fine. I use an Andersen hitch and can make a 90 degree turn, but just barely. With the Andersen hitch, you can mount the pin adapter either in front of or behind the pin to get the clearance you need.
Nice Toy Hauler! :)
From what I've *read* long Pin Boxes can take advantage of mounting the adapter to the rear to keep the Pin Box from damaging the side bed-rails.
I've also found a couple of guys who run a 4" offset ball in the bed, to move the hitch back, and then run the Pin Adapter to the rear to bring the pin forward the 4".
I *think* the success of this would really be application dependent, as the load center in the truck is still shifted back.
About Fifth Wheel Group
19,042 PostsLatest Activity: Aug 19, 2026
