nayther
Nov 04, 2013Explorer
rkortes wrote:
Thanks for the ideas and links guys. I'm leaning toward building some chocks out of wood to place up against the walls to protect the walls and keep the wheels straight while utilizing existing "D" rings in the floor. I did this in my enclosed trailer and it worked well.
I did something like that. Cheap Harbor Freight hoop type chock mounted on a piece of plywood with rubber on the bottom. Plywood jams up against the wall where it meets the floor, then front wheel in chock and tie it down, one tie down wrapped around the rear just to keep it from bouncing sideways. If you do two just reversed one from the other. I can put two across the back and still keep the couches folded down and lower the bunk enough to sleep above the bikes.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
