- neal10aExplorerI too am interested in the Lifestyle. After comparing it others in the same price point, I think it is the top of heap-- because of its engineering and flexibility of the factory to build what I want. I would like to hear both good and bad from actual owners. I too have not had good luck with their web site.
- Traveler_IIExplorer
rskeans wrote:
Just an update. I sent a msg to the Lifestyle forum administrator and received an email from Mr. Gentry with instructions. This problem is solved. Thanks to all for your contribution.
I'm glad that B.W. got back to you and helped you get in. The is an independent, self-supported forum and not connected to Carriage or Lifestyle in any way. I've found the members to really be helpful, hope you find out what you need to know. - rskeansExplorerJust an update. I sent a msg to the Lifestyle forum administrator and received an email from Mr. Gentry with instructions. This problem is solved. Thanks to all for your contribution.
- hone_eagleExplorer
here
this is what I clic on and post to. - rskeansExplorerWell guys, thanks for trying to get me on the right path. But everything I do requires the SN. It says that I must register, fair enough, but all registration leads to the same Owners Registration.
It would be helpful if somebody could locate the registration link to the forum that does not require the SN and post it. I tried the suggestions and it just does not work for me. - shadoowExplorerthe lifestyle website is a combination forum and owners club. Only owners (VIN) can access the owners info, but supposedly guests can access the forum. Maybe you're trying to register thru the owners club and not the forum?
- Traveler_IIExplorerI just went to the site, to join go to the right just below the the "red header that the Owner Club" and you will see "• FAQ • Register • Login" use the "Register" link to get into the site and ask your questions in the forum.
- Traveler_IIExplorerYou have the right web site: http://www.carriage-lifestyle-owners.com The "Owner Club" is just for owners of Lifestyle or Carriage and really is a small portion of this great site. The forum is open to all you can go in as a guest, I don't believe you can post, but you can read all the post or you can join if you have or have not a Lifestyle of Carriage. The people on the forum are great and can answer any question you might have. Try again, but not the section under "Owner Club".
Good Luck - rskeansExplorerCould somebody post a link to the 'open' section?
About Fifth Wheel Group
19,027 PostsLatest Activity: Oct 28, 2025
