Old-Biscuit
Feb 03, 2018Explorer III
Dry hitch weight means nothing ...... you don't tow a empty trailer
Dry hitch weight can give you an idea what trailers pin weight ratio is
A 13,000# DRY trailer weight (Unloaded Weight) with 20% pin weight would be 2600# DRY pin weight
Use that dry trailer weight to dry pin weight ratio to get an idea what trailers Wet pin weight could be based on the trailers GVWR
(16,0000# GVWR 20% pin ratio----3200# pin weight)
Pin weight ratios of 20% to 25% are typical
Heavier pin ...better towing result on a 5th wheel
AS suggested by LIMNLIN .....go get truck weighed 'camp ready'
Weight on rear axle subtracted from trucks RAWR equals amount of 'pin weight' you can add to rear axle before being overloaded.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 16, 2026
