mtofell1
Nov 11, 2015Explorer
I've had both over the years. I'm currently in a TT but am looking at going back to a 5th and the towing experience is definitely one reason. Just the physics of where the weight is carried is much better with a 5th wheel vs. a TT. Concentrating the load over the rear axle is MUCH better than letting it dangle from the bumper. Now, with all the modern anti-sway and hitches towing a TT is pretty comfortable as well in most cases.
Hitching both has pros/cons. Once the 5th hitch is in your truck it's much easier (if you can just leave it in your truck all the better) but moving that anvil in and out can be a pain. Hooking up the TT is a bit more work with the weight-distributing-hitch and anti-sway equipment but really is no more than 5 minutes once you have it down.
Backing I couldn't really say one is easier or harder. They're definitely different due to the hinge point being more forward on the 5th but you get the hang of it, it's super quick.... like the first time you do it :)
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
