goducks10
Nov 11, 2015Explorer
Other than the normal better towing characteristics I really like fact that I can walk between the 5th wheel and truck when hitched. I always hated trying to step over the coupler of a TT if I needed to get to the other side. If you don't have 4-6pt leveling on your 5th then it's likely you'll be doing some back and forth walking around while leveling and unhitching.
With a 5th you can cram the truck right under the over hang if needed for a short spot but still be able to walk between.
That and it's IMO easier and less cumbersome to hitch and unhitch. No sway bars or chains. You do have to hookup the safety line for brakes but it's way easier than cranking sway bar chains.
About Fifth Wheel Group
19,039 PostsLatest Activity: Mar 26, 2015
