Old-Biscuit
Apr 26, 2014Explorer III
Mile High wrote:
Check valves are only provided if the rig is equipped with a single valve winterizing system. It is on the hot outlet side and prevents antifreeze from returning to the tank with the bypass on.
A winterizing system with two valves, or no winterizing system, does not require the check valve and it may not have been installed.
Depends on where the 2 valves are installed.....
If just a cold inlet and a bypass valve then hot outlet would need a check valve to stop backflow when in 'bypass mode'
IF the 2 valves are 3 way valves then there may not be any check valves.
All depends on how/what is installed.
Sometimes the check valve is on cold inlet, most times on hot outlet.
They are an internal part of the 'nipple' right at the tank.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
