dogvetia
Apr 30, 2018Explorer
check valves
I have a 2004 winnebago Journey 36G. I have replaced the check valve behind the water hearer a couple of time. Today while unwinterizing all was going well after flushing the water heater and lines. While doing the sanitizing, the hot water taps began to flow slower and slower and finally barely a trickle. Well as in the past the check valve went south so I changed it--old one was fine and still have same problem on no flow or very little flow out of the hot water taps at all locations. Is there another check valve in another location--ie behind the city water fill panel??? Any and all thoughts are appreciated. Tom
