caysea7254 wrote:
We just picked up our 2014 3500 HD Silverado 4x4 Diesel. We went that way cause we didn't want to have any limitation for weight on the 5th wheel we pick out.
I think you will find you do have some limitations even with a great new truck. GM unfortunately is trailing in the tow capacity ratings when compared to the other two diesel truck competitors (Ram and Ford). I switched from GM to Ram for this very reason. There is of course even more capacity to be had if you wish to venture into a MDT or HDT.
With Duramax/Allison 4x4
3500HD Crew Cab Long bed DRW max 5th wheel weight is 22,600LBS
3500HD Double Cab Long bed DRW max 5th wheel weight is 22,800LBS
3500HD Regular Cab Long bed DRW max 5th wheel weight is 23,200LBS
3500HD Crew Cab Long bed SRW max 5th wheel weight is 16,900LBS
3500HD Crew Cab Short bed SRW max 5th wheel weight is 17,100LBS
3500HD Double Cab Long bed SRW max 5th wheel weight is 17,200LBS
3500HD Regular Cab Long bed SRW max 5th wheel weight is 17,500LBS
http://www.chevrolet.com/silverado-3500hd-diesel-trucks/specs/capabilities.html
