Dandy_Dan
Sep 09, 2014Explorer
RKW wrote:Open Range are separate slide motors. They have the BAL cable system which lightens the unit 3-500# per slide. All slide motors can be gotten to from inside the rig and worked with a drill with the flexible shaft supplied. Have not had a bit of trouble with the motors or the cable.
I was talking to a salesman about an Open Range "The Light" and he mentioned that the two opposing slides were independently actuated. He insinuated that other brands had slides that operated only simultaneously. He also mentioned that the slides on that particular RV could be opened out to any degree you wanted, that is to say a little or all the way or anywhere in between. That statement made me wonder if that feature was unique to most brands or common in most brands. Thoughts on this?
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
