goducks10
Jul 29, 2014Explorer
donn0128 wrote:goducks10 wrote:donn0128 wrote:
Double that and you will be close. That number is obviously based on dry weight.
It'll hardly be 3736lbs. 2600lbs would be closer.
At over 16000 GVWR it will likely be very close to double. AF are notorious for being very heavy
It's only 9650lbs dry with a 13,400 GVW. If the OP can load 3750lbs in it then maybe he'll hit 3000lbs on the pin. The fact that it has a rear kitchen will offset some of the front basement weight.
http://www.northwoodmfg.com/index.php?page=model&make=arctic&id=1050
About Fifth Wheel Group
