I had two of them before the 4 way pivoting hitch came out. I wouldn't go back to them.
Twice I've had the pin jam in the slot where the jaws can't open or close.
I carry lots of wood for leveling so luckily I had enough blocks for the truck and a 36" crow bar borrowed from a construction worker camped near by to get the pin out of the slot.
Back then RV parks were as scarce as hens teeth. Most campground had dirt roads and maybe scattered picnic tables with no level campsites.
Now if your staying in manicured RV parks with level pads then you should be ok. You may want to carry plenty of wood for cribbing....and a crow bar just in case.
