DutchmenSport
May 28, 2017Explorer
More than likely, there is a switch directly on the water heater, accessed from the outside of the camper. Remove the cover and look for a little rocker arm type switch. I think almost all water heaters are double switched: the switch on the wall inside your camper, and the switch on the outside of the water heater. They both need to be turned on. It's a safety feature to keep someone from flipping on the water heater inside the camper when there is no water in it.
About Fifth Wheel Group
