- Old-BiscuitExplorer III4th post........if you would stay with just one section of forum you could get more help.
Other posts water heater quit working, no spark etc.
Now it tries to light.
One of other posts
Maybe if you have MOD close all others and stick to one you will get better responses - Bad connection on the propane valve ground. Check where the coils of the gas valve connects to the mounting bracket. Normally it is in the back of the valve.
Check for voltage at gas valve while it is trying to light.
Check continuity on the gas valve coils.
Clean connector on the circuit board.
Do you smell propane at water heater?
Try lighting it with a long lighter while the ignitor is operating. Helper may need to turn on DSI while you are ready at the water heater.
Bad circuit board could be a possibility. - TodduptonExplorerDo you have voltage anywhere? Is it turned on
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
