WallynDiane's avatar
WallynDiane
Atwood water heater humming noise
I have a 2004 Holiday Rambler Presidential 5 th wheel rv. It has a six gallon propane/electric water heater. We just opened camp for the season and we noticed a humming sound (like a small motor running hum) when the unit was heating the water. It was not a running water sound and it stopped whenever I turned the heater off or it turned off itself when the water was hot. I had it on the electric option. By the way, the water got hot as normal. The humming sound was not loud and seemed to be coming from the back of the heater.
I called Atwood and they said that was highly unusual. They said it could be the heating element or the relay. But they were surprised by my problem.
Has anyone had a similar problem?
Access to the back of the heater is difficult. There is a small access square cutout in that black corrugated material that HR used to partition off the water heater.
Any help is appreciated. Thank you.
  • Have a 10 gal in a new HitchHiker that does that also, sounds like a sizzling sound when it is heating, figured it was normal, works fine.
    On edit, just remembered mine is a suburban, not atwood, still does the same thing.
  • Just thinking...have you flushed out the heater tank recently? If not, it might be full of 'crud.'
