RobertRyan
Sep 15, 2015Explorer
laknox wrote:
Robert, I know that, from past references, you have regs on the rear overhang. What kind of pin weights do you see on these smaller FWs, since the axles tend to be much further back, compared to U.S. FWs? Do the mfrs weight them to the tail to help compensate for otherwise heavy pins?
I =still= love that fully independent off-road suspension, though! :-)
Lyle
Good question. I really do not have an answer. I was looking at a manufacturer called Winjana RV , who make some " rustic" looking mainly Off Road very lightweight 5th Wheelers.
I will try and get some specs for you
The Ormistan 630
Heavier powder coated RHS 6” x 2” chassis rails
Tandem axle
Electric brakes (4 wheel) – off road
15” steel wheels with off road tyres
ALKO independent suspension/shockabsorbers
Breakaway switch
50mm towing pin
Drop/wind down stabilizing jacks
4” x 4” Heavy duty bumper with internal storage & spare wheel carrier
Manual wind down landing gear
2 stage drop step
External length 6950 mm
External width 2430 mm
Internal length 6225 mm
Internal height 1960 mm
Exterior height (over A/C) 3050 mm
Tare weight 2100 kg
ATM up to 2800 kg
Hitch weight 380 kg
* dimensions are approximate only
So it is tiny , 21ft long on par with a Scamp
or Escape 5ver Here pulled by a VW Van
About Fifth Wheel Group
