B.O. Plenty wrote:
I only put blocks under the legs if they don't hit the ground. You can raise the rears to put in a block but I don't think I would try the fronts unless it's hitched. In my opinion using blocks under the legs if not needed defeats the purpose of a Level up.
B.O.
I use blocks on the rears, since they only have about 8-10" of travel and, on uneven ground, can run out. I put a couple lego levelers under the fronts just for footprint. With the JTs I'm not nearly worried about the extensions causing wiggle. :B
Lyle
