Lantley
Mar 05, 2016Nomad
The OP asked for thoughts on the wheels off the ground scenario.
In the end they are different opinions. Some for, some against.
In the end there appears to be no consensus, just opinions.
If your owners manual says your OK to raise wheels you're good to go. If your manual says don't do it you are assuming the risk by doing so.
If you believe there is no risk or problem raise away.
If you prefer to always have wheels on the ground place support boards beneath the raised tires and you'll be fine
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 23, 2026
