busmanRG
Dec 25, 2014Explorer
Auto Leveling
We've pretty much decided to jump from our Class C to a 5th Wheel. One feature I'm sold on is auto leveling. As I look around ,that feature isn't offered on many of the units. We've seen many of th...
shepstone wrote:
Our cougar 28sgs came with 4point level up and it also came with the remote . Its a great system but it can be tricky if you don't use it enough . My initial difficulty was not realizing that the ground was more out of level than it looked and one of the rear jacks ran out of stroke (length). So it took me a while to figure out that initially I had let the front jacks down too far before letting the pins spring in , so now I only lower them by 5 of the spring loaded pin -holes before using the electrics to lower them to the ground to get the fifth wheel pin off the hitch . That way the coach can lower itself more at the front to level itself . Hope this explanation makes sense.. You also have to remember that it DOES have jacks down at the back before you take off... In a thunderstorm... In the dark... Late at night.... Don't ask me how I know...
