Busman,
Cedar Creek is a very good brand with excellent customer service at the factory. Silverback is made on the same assembly line. However, in the new Cedar Creek model line-up, the shortest one is the 34RL which is 36'8" exterior length. We have the earlier release of this model, the 34 RLSA. Same floor plan. It is perfect for us. The Silverback line has a model, the 29IK which has an exterior length of 33'11". They go up from there. Construction is pretty much the same. The CC is on a "Z" frame, which gives you more storage space in the basement. The SB is a flat frame. The major difference, other than that, is the CC has many things standard that are options on the SB. Of course, the CC is a bit more expensive as well. Go here: http://www.forestriverinc.com/CedarCreek/default.aspx. You can then select which one you want to explore and see all the floor plans and specifications of the CC and SB models. Good luck!
Skip
