time2roll
Oct 18, 2017Nomad
I think a disconnect box might work for what you need.
You just want to remove the box and connect wires direct right?
http://www.homedepot.com/p/GE-60-Amp-240-Volt-Non-Fuse-Metallic-AC-Disconnect-TFN60RCP/100674085
Alternative would just pull new wire and no box at all. Just leave a loop if you decide to add a TS in the future.
Also check your TS connections. Main cord should connect to the normally closed position and the coil not powered at all.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
