Gib3633's avatar
Gib3633
Automatic Leveler Calibration
We purchased a new fifth wheel with automatic leveler system. When it is finished doing it's thing the left front corner is low. My question is , does anyone know if there is a sensor to adjust, for example similar to adjusting a head light to correct this problem?
  • Try this from bigfootleveler.com:
    Operation Instructions
    Set-up #1: Programming Your Sensor
    1. Turn panel OFF, press FRONT 10 times, then press REAR 10 times.
    2. Follow the instructions on the screen for selecting ONE sensor using the arrows on the
    left side of the panel.
    3. Place a carpenter’s level on the inside of your trailer (countertop, refrigerator or floor).
    4. Manually operate by pressing FRONT, RIGHT, LEFT & REAR buttons to get the trailer level
    from front to back and side to side.
    5. Once level in both directions press ENTER. You’re done.
    From this point forward when you press AUTO LEVEL your trailer will return to this position.
  • I have the Big Foot and it was not level. I called the factory and they faxed me the instructions. It was a very easy process, and all was at it should be.
  • Not sure which system you have, with our Big Foot system you can program so that it's level. Depend on the model you have it's listed in the manual on how to do it. It's a simple procedure.
  • Check your owner's manual for the leveler system. I have the six point Lippet auto level system and there are instructions on how to calibrate the system to ZERO. I have done it one time and after many levelings of the RV it has not been out of level since that adjustment. Good luck.
    Lakeside
