- KID2TEXASExplorerSame as above I had to add a few level blocks just to be safe from time to time. Once you use it a few times you will know if you need to add a few just to give you more range. I love this system.
- dapperdanExplorerYou will be limited to travel the hydraulic cylinders need to "level" your coach. If the levelers are extended all the way and you're still not level your system should communicate that, you will then have to start over and place blocking under the levelers that reached their full travel. It will depend on how out of level the site you're trying to stay on is, if that makes any sense.
We have the Lippert 6 point level-up system on our RV and LOVE it!! Makes setting up so much easier.
Dan - DuckExplorerDon't know the exact answer but with our Level Up there is a limit on the travel of the jack it's self. On one occasion I had to add a couple of 2" boards on one side of the trailer to get the trailer to automatic level.
Don
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
