jdgreen42
Aug 06, 2014Explorer
The safety valve on the affected tank is likely stuck in the closed position. Disconnect the pigtail hose, be sure the tank valve is turned OFF. Insert a small flat screwdriver in the opening against the valve seat and give it a quick rap with the palm of your hand. Be sure the valve is OFF before you try this. You should hear a quick short hiss. Reconnect your pigtail and open the tank valve SLOWLY. It should work as normal.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
