glraz's avatar
glraz
Aux Fuel tank for Ford F250
Looking to add an aux diesel fuel tank to a ford f250 in the bed to gain 30-50 gallons in addition to stock tank. I live in Arizona and am getting mixed information from a few auto shops about what is legal and what is not DOT approved for all 50 states.
I am not a person that would under take this on my own so I would prefer to have it done by a auto shop.
I have seen Tranferflow, RDS Alum. and a few others but not sure I understand which ones would really work and/or are legal.
thanks for the comments.
  • Me Again wrote:
    Is your truck still in warranty? If so, I would talk to them first. With a F250 and pin heavy 5th wheel, you will have to watch your weights carefully. You could easily exceed your rear TV tire ratings. 50 gallons of diesel and tank could weigh in at 450+ pounds, with a lot of that on the rear axle. Chris
    I weighed it on the last trip and rear axle is still under manuf. spec and 50 gal of diesel will add about 365#. Even if I did 30 i would be happy. Has a little time left on powertrain warr left but not much. I did buy truck used so have 2 years left on a 3/36k extended warranty.
    thanks.
    Go to KSH in Lake Havasu city and have them make any size you want.
    chevman
  • Is your truck still in warranty? If so, I would talk to them first. With a F250 and pin heavy 5th wheel, you will have to watch your weights carefully. You could easily exceed your rear TV tire ratings. 50 gallons of diesel and tank could weigh in at 450+ pounds, with a lot of that on the rear axle. Chris
  • After having "Transfer Flow" install 3 different aux tanks, I strongly recommend them.
