packnrat wrote:
i just have a cheap 36 gallon from tractor supply. i had to add in one bung so i could have a sight tube. but i just flip a man valve to gravity drain into the factory tank. but i did weld in a connection to the factory fuel inlet (yes it was off the truck for this). and yes a fuel filter in this assembly.
O and i did add in a grounding strap, needed?? i get a lot of static discharges. can hurt at times.
i went cheap and simple.
Yes you need to get a good ground connection on the tank and usually that happens with the screws that hold it in place. Otherwise you need to get a wire from the tank to a clean part of the frame.
