Hello Folks, I have a 2008 Jayco designer 34RLQS. The awning (much like almost all I have seen) stops just on the other side of the door opening. The slide and its awning a few feet away. I wis...
Movable, ALWAYS cast shade in just the right spot, and no dependency on the awning when the sun is cast in the absolute wrong direction. They do work well with the awning to create a larger shaded foot print. Tilt them to block the sun when it's radiating low in the sky. They also fit in those spots where there are gaps in the shade, where sun beams through trees or anywhere.
