M_R_E_ExplorerMay 14, 2020Awning tie downsI have a Columbus 5th wheel with an electric awning that I tie down with ratchet straps. I was told you shouldn't do this because you can bend the tube unless you have a spring mounted on the end of t...Show More
enblethenNomadMay 14, 2020I would be more concerned about putting pressure on the gear assembly then bending the tube.
Related ContentTruck Camper Tie DownsIs one of your tie down tabs grounded?Awning tie downsTie downsTie Downs
