rtate
May 29, 2014Explorer
Axle Alignment
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side are wearing perfectly. I have one small slide on the door ...
rtate wrote:This is a bit eerie. My 3055RL is doing exactly the same thing. I don't believe it's the weight. We upgraded our axles from factory original 6000 lb to 7000 lb and tires to Goodyear G614's. We're on our way to Cody, WY where we will be for a couple months and am hoping to find someone/or some place to check my spring bolts for wear. The forward spring end mount of my rear axle where it connects to the EZ Flex appears off center, indicating wear, so that could be my problem. If so, I'll replace with wet bolts and check alignment to hopefully cure the problem.
Both tires on the door side of my trailer are showing are showing quite a bit of wear on the outside two inches. The tires on the other side .
I have one small slide on the door side and one large slide and small bedroom slide on the other side. So the off door side is carrying much more of the weight.
Is it possible that the weight distribution is causing the uneven tire wear and what can I do to correct it?
