John_Joey's avatar
John_Joey
Axle Alignment.
A friend of mine just pulled his brand new Jayco down south for the winter. He had one tire blow out, and unusual wear on the other front tire. The wear was like it was under inflated (but wasn't.) His concern is the axle might be out of alignment. If he was back home, no problem taking it in. Here he has concerns about the quality of workmanship given the lack of doing prior business with any of the shops.
How can a guy check the alignment to rule out this as an issue? Because we are away from our shops we have limited tools to work with to make the matter worst. Should be a simple way, just can not figure it out.
