N-Trouble's avatar
N-Trouble
Checking axle alignment
I was wanting to check the alignment of the axles on my trailer and was thinking of tying a weight to a string and hanging it from the kingpin then marking that spot on the ground. From there measure back to some point of the axle/wheel on each side and comparing. I realize this is a crude method compared to using a laser setup that I suspect most alignment shops probably use but would it at least tell me if I have any kind of alignment issue?
